Group: DynoMotion Message: 13273 From: engnerdan Date: 5/13/2016
Subject: Manual Tool Change Routine Modification
I am currently using the KFLOPManualToolChange.c program for handling tool changes. Each time a tool change happens the message box comes up on the computer screen requiring that I press "OK" to continue on with the G code.
My question is can I use my cycle start button (bit 1104) to effectively press the "OK" button? I know I could add code to advance the C program with the button press, but I am not sure about clearing the message box.
Dan
Group: DynoMotion Message: 13275 From: Tom Kerekes Date: 5/13/2016
Subject: Re: Manual Tool Change Routine Modification
Hi Dan,
There isn't currently a mechanism for simulating the operator pressing the OK button.
The only suggestion I have is to not invoke the message box.  Instead place a comment in the GCode for which tool is to be loaded and place an M0 in the GCode to halt.  Then Cycle Start could be used to continue.
Dan
Group: DynoMotion Message: 13277 From: Dan W Date: 5/13/2016
Bummer.
Doing the M0 thing is getting old. Having to hand edit each program after the CAM software posts it out. Some programs are 10,000+ lines of code. I will have to look at modifying the post.
I was using a wait for the cycle start bit to go high about a year ago after you patched it for me. But it seems that function is not working again in the full release of 4.33.
Dan
Sent via the Samsung Galaxy S®6 active, an AT&T 4G LTE smartphone
